those with eagle 589 or other alloy wheels in here
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GONZO2, Apr 11, 2002.
  1. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    what do use to clean your wheels?
    i'm starting to get some stains and other surface blemishes on my wheels and was curious as to what works without messing up the finish.
    these are eagle 589 high polished alloys.
    already tried one small spot with a chrome polish and i think it has too much scouring agent, i can see little swirl marks where i rubbed it in.
    any suggestions
    oh and i will be emailing the wheel manufacturer to for there input also, but i'm sure it will take them a while to get back to me.
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I use the Mother's Wheel Cleaner Polish and it works very well. I don't wash the truck all that aften, so I tend to get serious buildup between wheel cleanings, and the Mother's (and a whole lot of work) get them all pretty again. If you can find an applicator that works with a dremel tool or other high speed tool, you will save your fingers some pain - I usually end up with bleeding finger nails and numb fingers by the time I am done...
    As for regular cleaning (when washing the truck), I use Meguiar's Extra cleaner, it seems to work really well...
    By the way, I have the Eagle 589s...
  3. GONZO2
    Jul 17, 2001
    137
    thanks for the info
    i'll have to look for some type of soft attachement for my dremmel tool too.
  4. Philly87
    Philly87 1/2 ton status
    Jul 14, 2000
    465
    6
    El Paso, TX
    Eagle One "Never Dull" wheel polish works well too.
    Phil
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Either one works good (Never dull or mothers). I have the american Racing Bajas, so they are the same thing. I also have alot of polished aluminum on my boat and those two are the only ones that work good. BTW you think polishing wheels are bad, try my boat. I have a v-drive flat bottom boat, so everything is out in the open so everything needs to look good.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There was a post on here for a homeade aluminum polish that was suposed to be real good that I printed out a long time ago.
    Do a search.
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I use X-Treem. Cotton base with chemical in it.
    Awesome and easy to use!
    I purchased my last tub from Discount Tire.
    Do you have a high speed grinder? You can buff aluminum wheels easy with almost any polish once you get a buffing wheel for your grinder. The 7" pads from VA work great. Don't use it on your paint unless you have a variable speed unit.
