those with hydro assist and hydro boost...
Discussion in 'The Garage' started by ryan22re, Mar 29, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    what kind of pump are you running? just a stock, modded pump or aftermarket? just a rad hose to extend the filler or some other way to increase capacity? I was thinking of using a later model external resivoir pump. good idea or not?
    do you run a cooler? what i have heard, is that the cooler if any, should be mounted on the return side. correct or no? i would guess since its on the return side, it would be ok to use an auto tranny cooler as it wont see high pressure.
    have you ever had a problem with the brakes while at low rpm while working the steering?
    anybody have any idea what kind of pressure/flow id need to run both assist and hydroboost? or is it not enough to worry about?
    thanks in advance.
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    One of my friends has a setup-----------but he spent over $1000 for it to work perfectly w/hydro boost----what they did i dont know. ill see if i can find out---
  3. 425 Xpedition
    425 Xpedition 1/2 ton status
    Dec 4, 2001
    123
    Crosby, Texas
    I have been running Hydro assist with Hydro boost for about 5 years now. I just bit the bullet and bought the kit from AGR. Not the cheapest route but it was a complete kit with everything I needed. I was told by AGR that no modifications needed to be done to the Hydro boost. Also have a tranny cooler on the return hose from the steering box. Been working great and have had no problems.
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    i really dont want to spend 1k on an agr setup.
    need some more input.
    has anyone tried to fit a remote resivoir pump into v belt brackets?
  6. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Stock hydro boost pump, stock hydro boost, 2x8 tractor ram. Picked up a cooler last weekend that I plan on installing on the return side. My pump already had the remote res. I havnt had any issues with it as of yet.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I am planning on doing this mod soon (hydroboost equipped truck) and have been researching it.
    Several people have told me they have this system and it works okay. The only negative I have heard is that it's a little slow at lower rpm. For the pump mods, they are saying you can mod the pump for more flow but NOT for more pressure.
