Those with ONLY 4" of lift, what size tire you running???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FreedomIsntFree, Sep 3, 2005.
  1. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    I've got a 1974 K5. I am planning to run 37's or 38's on my 4" suspension lift with some fender cutting. I keep getting conflicting reports as well as downright insults telling me i'm stupid for wanting to run that setup. I guess they don't understand the whole center of gravity argument.
    Especially since I don't have my cage installed yet, I don't want to role the truck if i'm running w/out the top.
    So if you have only 4" of lift, tell me what you got! :D
  2. J.R.
    J.R. Guest
    i run 35-12.5-15 with 4in lift and no problems
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    b4 i added more lift, i had 4" and 35x12.50s, i would rub a lil bit when flexed out. with clean fender trim, 37x14.50 look really good. there quite a few people on here with that or similar set up.
  4. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    You can run 37'38 inch tires with 4 inch lift and fender cutting any day of the week. It just depends on how much cutting you wanna do. I would suggest moving the front axle forward to keep the tires out of the firewall while flexing. Good luck with your set up.
    Cory
  5. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    i run 32's on my K10 with a 4" lift and it has plenty of tire for the lift..........37/38's would look real funny on my truck.
    I hope you got Dana 60's to go with those big wheels.. :bow:
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    37 1250 with plenty of trimming.
    i ran 35 1250's for a short while and rubbed those pulling out of my driveway and of course offroad.
  7. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Check my sig.
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm gonna bring my truck down a couple of inches this winter which will set me at ~4" with 39.5" boggers. I'll have to trim more and pound the firewall but it's doable.
    EDIT: I forgot to say that the front axle is moved 1.5" forward and when I bring it down a little the axle will be moved another .5" to 2.5" forward, depending on what works.
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Dont let anyone tell you that your plan is not feasible. I run 4" bds front springs and stock rears with a shackle flip....and I run 37" mt/r's. It rubbed while pulling into my driveway until I trimmed it. Now that its trimmed, it doesnt hit at all. You might have to trim some of the inner fender and pound it back with a sawzall, but it definitely works. While your at it, buy some zero rates for the front and rear. They will add 1" of lift, and you can move your axle forwards or baskwards with them. They work really well. Especially in your case when you dont want to rub. Move the front axle forward 1" with them, and youll be better off.
    -Harrison
  10. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    4" rough country & 35X15.50 TSX's = very little rub at the front fender, rear corners. And that's with it flexed out. FIWI
    Who flamed you? Abunch of Heepers? :haha:
  11. FreedomIsntFree
    Aug 23, 2005
    124
    DFW, TX
    Thanks for all the replies guys. The truck is not my daily driver. So I can go a little crazy with it, but I just don't want a SUPER amount of lift.
    I have a buddy who's got a 2000 Dodge Ram with 15" of lift on 42s. He was the one who convinced me to stay low. He said he can't take it on a lot of trails cuz it's so big.
    As of right now I'm debating between 37x13" and 38.5x11" Boggers. I know the 38.5 is probably pushing it. But it's skinnier and should help with clearance.
    Basically the truck is for mud, trails and dirt. I don't like rocks cuz it's so hard of EVERYTHING. I plan on running my D44 until it breaks then getting my D60. I"m not sure how long the 12 bolt will hold up in the rear, but we'll see.
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run 37" MTRs with 4" of lift. I have a fair amount of trimming though. I still rub the inner fenderwells when I stuff the frontend hard. They work fine though.
    37" MTR's are only about 35.5" true height though.
    Harley
  13. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    i will be running 4 in lift, 1 in body, 38 15-50 16's and masive triming has been done allready.
  14. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    4" Tuff country in front, 57" f*rd springs rear with shackle flip.....39.5" Iroks.
    Minor fender cutting ;)
  15. nmud2deep
    nmud2deep Registered Member
    Apr 23, 2003
    63
    georgia
    i run 37s w/4inch sus and a 3 inch body
  16. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    I run a 4" with 35s and fender trimming but i plan on moving to 38s. But i'll probably have to trim more to allow for more room under flex. :D
  17. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    4" lift that is sagged (12 years old) and a 1" body lift. 39.5 x 15 x 15's
    Rene
  18. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    38.5x14.5x16.5 w/ 4" lift rubs firewall a little when flexed hard
  19. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    here's 4" TC lift and 36's
  20. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I run 4" TC front springs in the stock location and stock rear springs on a 4" shackle flip in the rear with 13/38-16 TSL's. Prior to the 38's I ran 35x12.50's on the same lift.
    With the swaybar disconnected the 35's required a small/moderate amount of trimming for off-road use but they never rubbed afterwards. After installing the 38's I couldn't even turn the wheel to full lock on flat ground without rubbing. The front fenders required trimming of the rear section of the inner fenderwells and pounding the firewall seam flat, but they still lightly rub on occassion. The front edge of the front fenders also required trimming.
