those with rears up front? most common arrangement?
Discussion in 'The Garage' started by ncgamedog, Dec 16, 2006.
  1. ncgamedog
    ncgamedog 1/2 ton status
    Oct 7, 2005
    130
    union grove, north carolina
    i have 4" TC ez-rides up front now but i'm ready to switch to rears up front on my k5. what is the most common way of arranging the leafs? i know on toyotas we always run the main and 2nd leaf with the rest of the origanal front pack? do i just run the rears as is or is it better to add a few leaves? i'm looking for something that can be managable on road, stability wise, though i'm aware it wont be perfect. i realy would'nt mind if the truck came down an inch or so also. i do have some 2" lift springs lying around i could bust up to build a pack w/. my blazer is a 78' w/ tons and 39's.
  2. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    read my 52" spring swap article in the tech section. It will get you right around 4" of lift... be very flexy etc. Stability on-road can be helped by running the right shocks and/or a anti sway bar if you don't like taking corners slow. Doesn't really bother me.
    Another alternative is to run 56s up front.... pretty much the same deal, you just need to relocate the rear shackle hanger to a spot 4" further back than what I talk about in the tech article...
    j
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    with 56's you can keep the shackle in the stock location, you just need longer shackles.
  4. 81K5GUY
    81K5GUY 1/2 ton status
    Jan 30, 2006
    943
    Rockingham ,N.C.
