Those with redneck ram
Discussion in 'The Garage' started by 85mudblazin, Sep 13, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    what size is your steering box tapped for?? And what size is the fitting that is on the other side of the fitting that goes into the box? (if that makes sense :crazy: )
    -Chris
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I just did my own using a PSC ram and the EMS Offroad front cap. The caps are tapped to a 1/4" NPT (same as most boxes) and the ram uses -6 AN fittings. you need two adapter fittings (1/4" NPT to -6AN). Checker performance has aluminum ones, home depot has brass ones.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I just bought the rocklogic kit and at the box it uses 1/4"NPT into the box and I guess the other fitting is -4. I am hoping my ram has the -6 fittings that are tapped into the actual body of the ram.
    ANYWAYS I ordered the WTO lines because the rocklogics dont have the 90* ends at the box side and the rock hoses are a little small for my taste.
    The -6 fitting loosk to be bigger then the 1/4" NPT thats tapped into my box, hopefully they use the 1/4"NPT to -6 and I can just get them from them.
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The ram fittings are usually hard welded into the body. The -6 is real close in size to a 1/4" NPT.
