Those with rollcages
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Roostr84, Oct 10, 2001.
  1. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    How much vibration should I experience in a professinally welded roolcage when going over bumps etc. Does anybody else notice this or is it just me.
    Chris =)
    I think the exhaust fumes have finally gotten to me!!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Vibration? Are you refering to the cage shifting/flexing?
    On the Hwy my cage doesn't vibrate or move. Now when wheelin it does shift/flex when I get twisty. I know this cuz the part of my cage that goes next to the window frame I can see the gap close between the bar and the frame it self. Never been a problem just flexin!!
    If yours is vibratin I would think it's loose or your body mounts are toast?????
    my .02c
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Is your cage attached to the frame? Is it attached w/ rubber bushings?
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. Roostr84
    Aug 19, 2000
    451
    NJ
    Mine is a smitty bilt full cage. It ios bolted to the floors. I notice that it flexs a little only when I hit some really big holes or rough roads though. i just wondered if this is normal.
    Chris =)
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have a roll bar out of a p/u bolted to the floor behind the rear seats and on top of the wheel wells in my blazer. I can hear it flexing (it makes a tink-tink sound) when going over nasty stuff. I wouldn't think a good wealded one would move....will see when I get mine. Do you have sandwich plates on the under side where it bolts to the floor?
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I have a 6-point cage and I experience some of what you are talking about.
    The cage moves slightly from side to side just a bit when going over potholes, flexing or bouncing offroad, etc.
    I have squares of rubber in between where the metal plates bolt to the floor. So there's no squeek. After I replace the body mounts I will tie the whole cage into the frame.
    Here's a pic of my 6-point cage:
    <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=92>http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?action=ShowPhoto&amp;PhotoID=92</a>
  7. Roostr84
    Aug 19, 2000
    451
    NJ
    Ryan sounds exactly like what you are experiencing. Oh well i'll live with it for now maybe I can anchor it a little better. We'll see. Thanks guys.
    Chris =)
