***Those with TBI, I need some pictures***
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Aug 3, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    For those who have TBI, I need some pictures of the fuel lines that leave the TB. I bought some fuel lines from the dealer for my swap but cant figure out how they are suppose to be routed.
    Thanks for the help,
    Charles
  2. dyeager535
    26,982
    191
    Which side of the engine do they come off of? For TPI mine are gonna come off the drivers side, but I've got stock '89 K5 lines maybe we can figure these out together if need be. The two large lines are obviously fuel out and fuel in (return) and the third one I'm presuming is still EVAP cannister.
    I didn't pull this setup from the rig though, so I'm partially lost as to routing myself. I notice the TPI intake has a bracket that holds the fuel lines to fuel rail in place, (and TBI lines bolt to the TPI fittings : ) so they really only go one way on mine. (although the rails look to fit on backwards too, they'd hit the firewall, but exit on the "right" side of the truck)
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I will go take some right now. Be right back.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Here are a couple. Let me know if you need more.
    and
  5. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    CK's (88 and up PU's) rout down the frame to the drivers side....88 to 91 RV K5's...Subs...Crew cabs...route to the pass side....
    Azblazer
  6. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thanks for all the help guys. DP_90k5 those pics helped out a great deal. Could you snap a few of where the hard lines meet the TB flex lines (on the frame rail) and some of how the lines go down the block?
    Thanks,
    Charles
