Those with TC 6" front springs
Discussion in 'The Garage' started by 85mudblazin, Aug 5, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Those with TC 6\" front springs
    I am looking to get the TC 6" springs and I was wonder how well they flexed, and how well do they ride on the road?? I have ROUGH country 4" spring now and I want to go higher and have a better ride would these be a good choice?? opinions??
    -Chris
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Re: Those with TC 6\" front springs
    6" springs won't flex very good, but better than a 6" rough country would.
    tuff country and BDS are the softest riding springs (besides custom made ones) so they will still be able to flex.
  3. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    front or rear? if front then open up the clips, if rear then flip the overload. either way the TC softrides are the best springs for the price.
  4. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    dont forget the option of the ORD zero rate add a leafs and some fender trimming or the 1" body lift (gives a good opportunity to change body mounts as well). /forums/images/graemlins/k5.gif
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    well later down the rpad I am shooting for 8" of lift and I can no way do that in the front with a 4" spring so that is why I was looking at the 6" then I could do a 1" body lift(max I will go) and add some zerorates and that will put me at 8". I just hope they flex good.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] 4" Tuff Country spring, ORD 4" Shackle flip, ORD Zero rates, and 3" Body lift would be 8 inches of total lift Note, the ORD Zero Rates will give you 1" of lift. I'm not a fan of body lifts, but you can get 8" lift with 4" springs and have lots of flex, and a quality ride. /forums/images/graemlins/thinking.gif
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I dont like big body lifts the max I will go is 1" thats just how I feel.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I can understand that, I feel the same myself, but I just thought I'd throw that out sence it can be done.
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I went from 4" rough country's to 4" BDS and the flex difference is amazing. I know TC and BDS are real similar on fles and ride, I say go for it. At the least you won't have any less flex than the rough country's.
    PS IMO flex is a word that is useless if keeping a swaybar. /forums/images/graemlins/grin.gif
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea my swaybar is already gone since I had my stiff A$$ springs, ill just get some disco's if it is to flexy on the road.
  11. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    that's why I got the sway bar dicso /forums/images/graemlins/waytogo.gif
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    what size tire are you planning on running?
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I have 35's now and I plant to get 38x15x15 after I swap in the 14bff rear.
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif and you can fit them /forums/images/graemlins/waytogo.gif
    http://community.webshots.com/photo/132957664/149697021ZYmSVz
    those are 36" and 4" lift. I know I have enough room to fit larger tires.
  15. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    They can be a little soft with the top on, but it is doable. If it is too scary go to discos (as mentioned above) until x-over.
    Once flex is found x-over becomes a high priority.
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yea I am trying to save the x-over untill I can get a D60 so I dont wasnt too much money on my 10b.
  17. sidslc
    sidslc Registered Member
    May 27, 2002
    96
    slc ut
    follow the pics link and look at the flex on the front of my blazer they are tc 6in ez rides they work great.
