Thought I had a Detroit, Turns out it's a Gov Bomb
Discussion in 'The Garage' started by MTMike, Jan 17, 2006.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    When I was out pounding snow drifts this weekend, my would-be Detroit would disengage at all the wrong times, or allow 1 tire to spin slower than the other.
    So when I got home I jacked up the back and thanks to some advice on here via the Search button, I found that I could test what kind of locker it is by turning the wheels. Sure enough, as I spun 1 tire, the other went in the opposite direction until I started to feel some resistance, then the other tire slowed, and then start spinning forward with the one I was turning. A clear indication of a Gov Lock according to several posts made in here in the past.
    Upon this news, I called my buddy who happens to have a spare open 14bff Diff and a welder, and he's gonna Lincoln Lock my 14b for me until I can come up with $400 bones for a detroit. Thanks Joe!
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    If I were to do it agian I would stick with the welded rear end and spend the money on a detroit for the front. Now they have spools for under 200 bucks too, another good idea.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Don't that suck. I'm sure you'll be happier knowing you are locked now :D
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yup, as long as it's a good weld job, I would save my money for something else. I have actually been thinking of taking my detroit out and selling it so i can buy other much needed parts. Then just welding the spiders up.
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    The thing is I have a bunch of other sh*t to buy for the truck (rear disc conversion, winch controls & accessories, possible k5 body swap) and running even another $200 by her will send her through the roof :D Gotta keep momma happy, so I'll run welded for a while.
    The truck's a trailer queen anyways so I'm not that concerned.
    Can you tell me more about spools? How do they work, how do they compare to detroits?
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Spools replace the spider gears. Or I believe you can buy one that replaces the whole carrier. It is like having your spider gears welded, but its a solid piece or metal. Just locks both shafts together.
  7. Esteban86K5
    3,712
    Bakersfield, CA
    The picture above is a mini spool that goes inside your stock open carrier. A full spool replaces your entire carrier. Both will not allow your tires to turn seperately like a detroit does when it's unlocked. But if your truck is a trail only vehicle then it really doesn't matter if your tires rotate seperately or not. The detroit is made to disengage for street friendly manners.
  8. Esteban86K5
    3,712
    Bakersfield, CA
    Another thing to consider when you thinking of mini spool or full spool is that with a full spool you will need your gers to be reinstalled to proper specs. If you just install a mini spool you can do it without worrying about throwing out the specs of the gears.
  9. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Here's a full spool for a 9" Replaces the whole carrier like esteban said
  10. goldwing2000
    goldwing2000 Guest
    E-mail me if you want to sell that Detroit!
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    even if he just replaces the gov-bomb carrier with an Open he should resetup the gears... there is no garauntee that the carriers are exactly the same in everyway.
  12. Esteban86K5
    3,712
    Bakersfield, CA
    Yup, forgot that he was thinking of replacing it.
    You can also just weld up the gov bomb and slap it back in there.
  13. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I like both my detroits.. I was gonna weld too as I have a spare set of spiders...
    however just like everything else... it is an investment.. plus unlocking while cornering on the pavement is a nice feature :haha:
  14. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Are there pictures of this process around here, do you know?
    Thanks,
    Mike
  15. Esteban86K5
    3,712
    Bakersfield, CA
    Do a search on here and on Pirate. I think I may have seen one on Google too.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    open carriers are plentiful enough that personally I'm gonna weld it all up and if I find I want some unlocking I'll get an ARB or another open carrier to put a detroit in. I mean, I can pick up 14 bolts easily for $100, probably get a carrier for pocket change.... wait I think I have a spare open carrier... ha.
    Oh and as for welding a Gov-Bomb, Jjlaugner is the one who first did it around here. I can't help more than that.
  17. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    Come on Mike, nut up for the new ARB 14FF locker. Then install cutting brakes. Sweet.
  18. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    When I start sh*tting gold nuggets, we'll talk, until then...... :D
  19. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    any body got pics of a welded gov bomb?
    thanks,
    James
  20. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
