Thoughts On Barrel Fluting?
Discussion in 'The Lounge' started by mikey_d05, Jan 7, 2007.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I bought a Remington 700 in 300 Win. Mag. from my uncle. I've already got a 300 mag that shoots well. I wanted something to take apart, accurize, rebarrel, re-stock, pillar, bed, free float, etc. Basically, it's gonna be a 10+ pound rifle that'll push a 125 grain slug at 3200+ fps and be a tackdriver out to 500+ yards.
    From looking at different barrel contours and the estimated weights, I could potentially shave 1/2 pound off my ordering a fluted barrel. It's already gonna be a heavy contour and a heavy rifle, so I don't know if that 1/2 pound is worth the extra expense.
    Does fluting of a barrel provide any additional benefits? I would assume it would act like a heat sink and cool the barrel better. What about rigidity and vibration?
    Based on weight and cooling alone, I would rather stick with a normal barrel. However, if fluting has any additional benefits, I would reconsider.
    Don't ask me why I'm doing this, my uncle bagged an elk, a black bear, and a mulie (at 450+ yards) with this thing in it's current form...with 1 shot each.
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Take both guns out and group them, side by side. Work over the one with the largest groups. That way, if you screw up, you still have one good rifle. 3200+ is gonna be a barrel burner, if you shoot many of those rounds.
    I don't think you will notice a weight reduction of 8 ounces. Heat dissipation on a bolt action, hunting rifle isn't really an issue, unless you are loading and firing as fast as you can.
    Glass bed the action, use a GOOD synthetic stock, free float the barrel, good adjustable trigger. You can get good groups at 500 yards, but only on a calm day.
  3. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Oh yeah, a 5" group at 500 yds, is 1 MOA, better than I can shoot.:doah:
  4. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Fluted barrels are a waste of money on a hunting rifle. Unless your going to be toting the thing long distances, or just like the way they look. That's my opinion.
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    The other 300 is a browning a-bolt, sooo...not near as common for parts and such. I'd like to work over the Remington because of ease and parts availability.
    Besides, all of my a-bolts shoot 1/2 MOA or better, my .243 shoots 1/4 MOA consistently on a calm day. :eek1: I just want something to make my own and see if I can do better.
    I think I'll stick with a lighter contour and no flutes. Like I said, it's gonna get pillared, bedded, barrel will be free floated, action blueprinted, etc. My dad has had good luck with Canjar triggers but after tweaking the Remington one last night it seems pretty decent.
    Got any recommendations for stocks? My current two favorites come from McMillan and MPI.
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i am sorry to bud in gun are good and all and all guns are nice.
    but your wrecking my streak you see....
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Huh? I'm confused...
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i have the last reply in many threads this morning.
    OK i am bord not working today and am randomly responding to posts, you guys also postsing are bing a bit of a damper on my little party here..
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    a fluted bbl. is strounger, lighter, and will cool faster than a bull bbl.
  10. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Yep, what Surpip said. All about the surface area.
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Kert is that what that new rifle you got has? a fluted barrel?
  12. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    I thought barrel strength was directly related to barrel diameter? Fluted barrels are as strong as ones not fluted of the same size. I get the lighter and cooler, but I don't believe flutes will make one any stronger.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I would be wiling to bet a large sum of money that if you took a bull barrel, and a fluted barrel of the same max outside diameter, it would take quite a bit more preassure to bend the fluted over the non fluted barrel.
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I R Stoopid. What the **** is a fluted barrel:doah:
    Ira
  15. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Sorry, but that just doesn't make sense. The barrels are the same major diameter and you're removing material from the fluted one. I'm not planning on driving a truck over this thing so it doesn't really matter but unless you brace the barrel in some other way...a solid piece will be stronger.
    If there's some work hardening that happens in the fluting process, then it's understandable.
  16. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    correct.
    With the same OD, ID, and the same material (no strengthening) the bull barrel, with more material, will be stronger than the fluted.
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ok, back to the main question, in a 12 or so pound rifle that's not gonna be a prarie dog rifle, is a half a pound worth $100?
  18. BigBen
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Back on track....
    Not worth it if it's my rifle.
  19. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  20. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
    Damnit. If I'd have caught this post earlier, I could have made some dough, or wagered you out of your tires:doah:.
