thoughts on this shock mount setup...
Discussion in 'The Garage' started by beater_k20, Jun 28, 2006.
  1. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    opinions of why and why not to use this setup....
    more detailed pics can be found here: http://www.offroaddirect.com/Install/SAS001.pdf
    basically, mounts the shocks to the front spring plate, and the tower that bolts to the frame.
    i've been racking my brain and reading everything i can find on suspension design, and i am OH SO CLOSE to just ordering their complete SAS setup and being done with it.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    because youd have to cut the coil bucket out of the way and f 250 shock towers are cheaper...
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    That and i dont think youll get a ton of travel out of em, that not a very far dstance from top of spring to where that mount 'el be.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    coil buckets are no longer an issue, i picked up a K1500 frame last night.
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    If theres no coil buckets then just run ford towers...Would be much cheaper. I got a set of super duty tower i may be willing to part with :whistle: the mounts on the axle will work fine w/ no buckets in the way, you may just have to persuade them slightly:D
