Thoughts , Opinions , Advice
Discussion in 'The Garage' started by big jimmy 91, Mar 20, 2005.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I am looking into purchasing a 91 Blazer f.s. that was involved in a highway mutiple roll over this winter
    This may be used for parts or mabey put back on the road for a thrashing type rig (all body panels are smashed up allready:tongue1: )
    It is identical drive train to my Jimmy which is a good thing
    Now since it was a severe roll crash , what things should I look for that my be damaged beyond use in the drive train??
    Bent axel housings?
    cracked cases etc. (trans. t case)
    bent rims (minor)
    Or other things to consider?
    If anyone has anything more to this , please add anything else I should consider before a purchase is made
  2. big jimmy 91
    Feb 21, 2004
    639
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    bent frame, big deal, hard/expinsive to fix
  4. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    The leaf spring eye mounts on the frame may be bent.
    The whole frame could be bent/out of square.
    I think....:doah:
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    All of the above, and more.
    Being the FD I have made many a wreck and a lot of parts can get wasted from high speed rolls, and or impacts. We clean up all the fluids that are left on the road. Many times while waiting for the tow truck, out of bordem I have taken the time to look over the drive train, easy to do when it's on it's side or upside down.. :p: I have seen some pretty bad fractures in diff housings, T cases, trannys etc...
    Like someone mentioned, spring eyes get yanked, and elongated... shock mounts get ripped out of the frame... or cause a tear there. Look for any gear oil running into, or standing in the drum. Thin metal parts like fuel tanks sometimes get torn when the tank is pretty full, and end up with slow leaks.
    Sooo.. give at all a very good going over before you buy. Also, if you find that most eberything survived (very poss if it was going slow enough when it went over) at the very least, even if you plan to wheel it as a beater.. make sure you go with a full cage. Now that the cab has taken the shock of a roll, it will be more likely to crush down in the event of even a slow roll while wheeling.
  6. big jimmy 91
    Feb 21, 2004
    639
    Thanks , I knew there were more things to look for that I did'nt realize , or think of.
    Well I will go and have a close inspection of this rig as soon as I have the cash in hand
    Again thanks for everyones input :waytogo:
  7. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Rolls
    A few friends have bought some "light rollover" repairables from junkyards--they found a lot of cracks in the frames behind the steering box(a weak spot that often cracks anyway)and the rivets that join the crossmembers were sheared off,and not readily noticeable--other than that I'd look real close at the frame and make sure its not "tweaked" and the axles and springs and the spring hangers--one truck had a warped axle flange that wobbled so bad you couldn't drive it--had to replace the entire axle housing--another axle would no go in when he got another shaft at the junkyard,the axle tube bent right at the carrier...--If you are going to beat it up anyway,you might be better off with a low priced rusty truck rather than one thats been rolled..:crazy:
