Thread sealer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Jimmy, Mar 10, 2004.
  1. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    Hello,
    I'm installing the heads on my rebuilt 350. Last time I did heads, I used a teflon sealer that came in a tube from NAPA. ( I'm talking on the headbolts, not the gasket.) The local NAPA doesn't carry it now. Counter guy suggested a high temp RTV silicone. Years ago, I remember my Dad using brown Permatex gasket sealer, I think. A local engine builder said he uses teflon tape. I always thought tape was to allow better tightening, but was not a sealer. No? Can anybody tell me the current hot setup for sealing headbolts? Thanks.
    John
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use teflon tape. works great. just make sure you run a tap through the block /forums/images/graemlins/waytogo.gif
  3. 89Jimmy
    192
    Already ran a tap through 'em. Just one layer, like doing a pipe fitting? Thanks.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Get a tube of Permatex Form-A-Gasket #2 Non-Hardening Sealer. It's awesome stuff. /forums/images/graemlins/thumb.gif They also make a slightly thinner version that is in a can with a brush applicator. It's called Avaition Gasket Sealer, or something similar to that.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i normally do two.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Permatex still makes thread sealer, and I would use that.
  7. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I got the thread sealer from GM it isn't cheap but on a $5000.00 motor what is an extra 10 bucks at least that was my reasoning.
