Thread Size for TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Madbomber88, Jan 1, 2007.
  1. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    Does anyone know what the thread size is on the Throttle body for the fuel line and return fuel line?
    I'm converting my 72 K20 to TBI and want to use Aeroquip's socketless tubing, but need to know what fittings to get, and they list them as NPT and AN. I know the threads are metric.
    Thank you in advance.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    supply line is a 16mm saginaw fitting and the return is a 14mm saginaw fitting. That is what is on the end of the factory TBI fuel lines that go into the adapter on the TB. I dont know what kinda of thread the actaul TB is threaded for. All I know is that they use teflon flat washers to seal
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You can buy the proper fittings from turbocity. They accept a push on hose.
  4. Madbomber88
    Feb 7, 2001
    185
    Mass
    Thank you, that's exactly what I needed.
    Next and last question: the feed line is 3/8 and the return is 5/16. Is there anything wrong with replacing the 5/16 one with a 3/8? I can only get the tubing in -6 (3/8) size. What will this affect?
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It'll be fine if you can get it to seal on a 5/16 fitting. Earls do a braided black hose that is 8.9mm i'd which is between 3/8 and 5/16, that's what I use.
