Thread size on Ubolts for ORD flip Kit
Discussion in 'OffRoad Design' started by silveradoreb, Mar 11, 2005.
  1. silveradoreb
    silveradoreb 1/2 ton status
    Mar 11, 2005
    150
    Boone,NC
    I was wondering what size ubolt thread the ubolt plate is made for. Is is 9/16 or 5/8 etc. I couldn't find it anywhere else, thanks
    By the way its the 1/2 ton kit.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    5/8 fine which is pretty standard for GM fullsizes.
  3. silveradoreb
    Mar 11, 2005
    150
    Boone,NC
    Thanks, So I have a 02 Silverado 1500 with a corporate 10 bolt, so the U-bolts need to be 3 inches wide for my axle tube correct? Thats all I needed thanks
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It should be a 3" tube, you might verify that. Also check to make sure there's enough clearance for the plate on top of the leaf spring. On some trucks with upside down ubolts, there isn't room to put the plates on top without hitting the frame.
