thread taps, cutters, and where to find ?
Discussion in 'The Garage' started by R72K5, Jun 23, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok i need basic info on taps and cutters and etc
    what is what and where do you get them ?
    is a tap technically a thread cutter for a drilled hole ? or is a tap technically just a chaser ?
    can i find this stuff at napa ?
    dont have anything else in town cept a little farm supply store and auto zone and o reilly's
    anyone know any links that show how to drill and thread holes ?
    also what type of bit will drill a broken bolt out ? where do i find a centering bit for this ?
    thanks
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Another online vendor is ENCO. Travers tends to have the odd-ball tap sizes that others don't stock.
  4. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Yes a Tap is used to cut new threads into a drilled hole
    You can also use it to fix damaged threads
    A Chaser is good for cleaning out threads
    A Die Is used to repair studs or bolts
    An Easy-Out or Extractor is used to remove broken bolts
    Unlike other tools Taps, Drill Bits, and Extractors are not warrantied against breakage so I tend to buy the cheaper ones. Also Ive found that when I have broken one the cheap ones drill out easier.
    My favorite place to get them are swapmeets. Usually there is atleast one vendor there selling cheap tools. Ive picked up entire sets for $20
    Email me if you need pictures or have other questions
    uglyangl@lycos.com
  5. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    I don't like msc they do not deliever same or next day real good. Mc master carr if call early is usually ther the same day if in stock or in the evening the next morning. If drilling out abroke bolt on your truck what are you looking for a center for? Will not drill and use an easy out work? then just chase the threads with a tap. Use the chart and drill the hole needed to tap what ever size hole you want to tap then use a starting tap and some cutting fluid and work the tap in back and forth pulling the tap out a couple times to clean the chips out. A tap handle is nice sometimes (hard to get to area) but not nessesary.
