Threads on battery stripped any remedies?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 24, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I have the side mount type battery with the terminals that screw in. The lead threads on the battery are stripped so I cant get a tight connection. What a lame design. Is there a way to rig it short of getting a new battery? Thanks.
  2. dyeager535
    26,975
    Don't see why you couldn't thread it with a larger tap...they are only lead I believe, so pretty soft. You'd have to get a matching bolt for the new threads, and knock the one out of the battery cabel, but shouldn't be too complex. Believe me, this design is much better in a car/truck than top mount, EXCEPT when you have to hook up jumper cables etc. They seem to corrode MUCH less than top terminal batteries.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. 87JIMMY
    87JIMMY Registered Member
    30
    MN
    Had the same happen to mine. I "temporarilly" used a course thread bolt 1 size larger and self tapped it into the soft lead. My bolt was way too long so I had to stack washers to get it tight, not to safe, but it worked.
    Good Luck, Scott 87 Jimmy
    Scott 87JIMMY
  4. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    I don't know about you but i buy the batteries that are top & side mount. So my cables are hooked up to side mount and i have the top ones for giving jumps or hooking more stuff up or whatever. IF you had that kind of battery you could just convert yours to top mount.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I have the same thing there MICHIGAN BLAZER. I tanked my passenger side battery (I have 2 since I am a Diesel). The side positive post on the drivers side is hooked up to the pos on the passenger side. I then used a top post 0 guage wire to goto my starter. Much better connection.
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  6. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Boy, oh boy, as many batteies as I've put in over the years(don't I sound like an old man,) have NEVER stripped one out. I think that they're a good design. Have tried to repair the so called "heavy-duty" top end adapters with Helicoils, don't waste your time using them, they only work a few times. Get yourself a new battery. GOPHERKILLER
