Threw a code
Discussion in 'The Garage' started by sandawgk5, Feb 23, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I was cruising around the other day and threw a code, it only happens at a certain throttle position. The code is Low TPS Voltage. I have done no other troubleshooting and I have to assume this is the original from 1987. Should I just buy one from the parts store of your choice and replace it or is it possible to adjust it.
    The code comes and goes and it seems to always be at the same throttle postion almost as if the resistor is damaged from use in one spot.
    Ira
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    sounds like its time to replace it :)
    Betcha you get a way better throttle response with a new one -- I imagine this one is probally fairly low across the board...
  3. sandawgk5
    Oct 28, 2003
    6,881
    Ira
  4. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i'd just replace it there not that much.
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    He means, if it's got low voltage across the board (across the sweep), it isn't juicing the engine correctly for the amount of throttle input you got on it....so you'll get better performance with a new one.
  6. sandawgk5
    Oct 28, 2003
    6,881
    K was confused about the low across the board. I guess I gotta go get me a new one:o .
    Ira
  7. Russell
    Jun 23, 2000
    7,923
    333
    Exactly!
    As these things get older, their resistances increase, so it doesn't send accurate throttle position data to the computer :)
  8. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Much like my 20 year old headlight switch/dash light dimmer. New switch, cleaned contacts and grounds - which caused my headlights and dash lights to get about 50% brighter! :D Now to get that HD light harness and the Hella H4/H1 upgrade installed...
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Hijack.
    How do you get the codes for a 91 Blazer? My service engine soon light has come on a few times in the last 3 days.
    Hijack off.
