throdle body
Discussion in 'The Garage' started by 89 k5 blazer, Jan 26, 2003.
  1. 89 k5 blazer
    89 k5 blazer Registered Member
    Jan 21, 2003
    13
    Rockville, MD
    i have a friend with a 89 k5 that put a throdle body spacer in and about 1000 miles later his trans blew up. is there a reason for this or just coincidence. /forums/images/graemlins/rolleyes.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Was the TV cable adjusted after installation of the spacer?
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    just coincidence /forums/images/graemlins/shocked.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When you raise the throttle body you also change the distance between the throttle body and the transmission. This can mess up the adjustment of the throttle valve cable, which controls the line pressure in a 700R4 transmission. When that adjustment is screwed up, the tranny can self destruct. So not only did your buddy waste $90 on the spacer (which doesn't make hardly any difference in the way the engine runs) but he probably wasted his tranny too. /forums/images/graemlins/angryfire.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Usually you have to adjust the TV cable after putting in a TB spacer. Some raise the TB up 1". That much lift will change the setting and the whole geomerty of the TV cable. Usually raising the TB will pull out the cable increasing pressures at low RPM and change the way and RPM at which it shifts. Dont know for sure if that caused your friends tranny to go bad but proper TV cable adjustment is critical in a 700r4. If it is not adjusted right it will damage the tranny in a short time.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Now if I'm using a 400 tranny, will I have TV adjustments to make after installing a spacer?
  7. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what kind of spacer are you going to use ?
  8. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    what kind of spacer are you going to use ? i need more info !
    I was planning on using the Helix spacer, the one that has the vortex grooves in it. But should I think twice about it, is there a better spacer out there that I should go with?
  9. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what kind of fuel delivery system are you using ?
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I'm using Crossfire TBI. Does that help out?
  11. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Guy who put the engine in my truck put in a spacer (need vac. source for brakes). He didn't adjust the TV. Roasted my 700R4 that had been rebuilt not too long ago. Now I have a 400.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Crossfire TBI? Is this on an '84 'vette or a Camabird? /forums/images/graemlins/shocked.gif You'll need two spacers for a Crossfire TBI system.
  13. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I didn't know that. Should I go ahead and use the spacers and what adjustments will I have to make?
  14. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Is this on your K5? Crossfire TBI was only available for a few years and was never offered on trucks. It was a special intake that had two throttle bodies. So if you have 2 throttle bodies, then you'd want to put spacers under both of them. But I'm still not convinced that a throttle body spacer makes enough difference to justify their ridiculous price. /forums/images/graemlins/shocked.gif
  15. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I think he's jackin ya
  16. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Naw, not the ultra-stable, level-headed Bubba Ray! /forums/images/graemlins/wink.gif
  17. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Bubba, does this helix spacer have the "vortex grooves" on the inside of it or on the outside of it?
    /forums/images/graemlins/deal.gif /forums/images/graemlins/ears.gif
  18. Ryan B.
    Jul 18, 2001
    5,693
    CA
  19. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    When you start messing around with the fuel system you need to be extra careful! Having hot gas blasting around and catching the cars next to you on fire is not what you want! Please dont drive around with a gernade on wheels. Think of the children.
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    The grooves are on the inside.
