Throtle Shaft leaking, just change the Seal?
Discussion in '1982-Present GM Diesel' started by Jaguargt, Aug 6, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    Should i just change the Seal of the big bolt that holds the throtle shaft, somebody did shows me a disasembled pump, and in the bolt only uses a seal like a o-ring, can i just change it if i have a leak there? thanx.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
