throttle body questions
Discussion in 'The Garage' started by bad_bo_ti, Apr 19, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    just wondering what or if there are any differences in the 4.3 305 and 350 throttle bodies? looking to get one to modify but the 350s are a little pricey! thanks, chris
  2. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I know you can bolt on the TBI and intake from a 305 to a 350. The injectors are different though. I currently have a 305 w/TBI and plan to build a 350 this coming winter.
    jason
  3. bad_bo_ti
    1,027
    OhiO
    thats kinda another things i thought of, is maybe just the injectors are different and i could just take my 350 injectors out but the bores might be diferent, i think the big block bores are bigger, i wouldnt mind gettine a 454 t.b. as long as i knew the differences. thanks for reply though.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Like said before, I believe the 4.3 and the 5.0 and 5.7 all use the same TBI just different size injectors, the 7.4 I know uses a bigger bore TBI and also the TPS switch is different but there is a harness to adapt to your wiring.
  5. bad_bo_ti
    1,027
    OhiO
    ok thanks alot /forums/images/graemlins/thumb.gif so does that mean the 7.4 uses different injectors than a 350 and if so would it hurt to run them in the 350?
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The 454 TBI injectors are rated at like 85lb/hr /forums/images/graemlins/eek.gif That is a little too much fuel for a 350...unless you can increase the amount of air into the engine by the same proportion....
    Chris
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Did someone say turbo? /forums/images/graemlins/thumb.gif
