throttle body spacer
Discussion in 'The Garage' started by blackblazer717, Dec 16, 2004.
  1. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i installed a airaid throttle body spacer on a 88 k-5 5.7 tbi i need to know why it is high idling at 2300 and the trottle plates are closed. dont know why... could i adjust the TPS or no?
    thanks
    luke
  2. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    my bad i can adjust the TPS any idea why it is high idling?
  3. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    854
    Pinckney, MI
    yup air leaks
  5. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    thanx guys for the support
    ill fix it tomorrow
  6. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    let us know how it goes....i am thinkin of getting one too...
  7. kick
    kick 1/2 ton status
    Dec 19, 2002
    385
    FL
    It also could be the throttle cable is too short now that the Throttle body is higher. check cable length.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Those air aid TB spacers are thick. If you have a 700r4 auto trans you better adjust your TV cable too. Or you may be buying a new tranny soon
  9. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    when i did it a couple weeks ago, i can verify the throttle cable issue... its borderline long enough with the spacer.. with just adding the spacers to the throttle bracket, the cable was barely long enough. even worse, the end tube part would hang up a little on the stationary part because it had gone past the point where it had a "guide". ended up having to tweak the bracket a little..
    found my tv cable, although functioning fine, needs replacing from where it had apparently been laying on the exhaust at some point.. :doah:
  10. kick
    kick 1/2 ton status
    Dec 19, 2002
    385
    FL
    GOOD point about the TV cable. It's been awhile since I've done the TB spacer.
  11. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    how do i adjust the TV cable? because i looked anyd both the throttle and the TV cable are at nasty looking angles....? i put a new gasket in and it runs fine now, i need to test drive it
    but i wanna know how to make a bracket or something because i dont like how those cables look on the intake
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    my TBI spacer came with 2 spacer sleeves to go under the throttle bracket to raise it up... if you didn't get any, you could get 2 longer bolts and cut down some long spacers from various alternators.. they where about 1/2"...
    to adjust the tv cable. depress the button and pull the cable all the way back into the housing. then give it full throttle with engine off. the cable should "click" out a few clicks..
    heres a link to a more detailed description.... http://www.powerdemon.com/PowertrainPointersFEB03.html
