throttle body spacer?
Discussion in 'The Garage' started by otisringle, Mar 4, 2007.
  1. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    While sittin in my "office" doin my morning thang, I came across a throttle body space in a magazine. Says that it helps with enhancing power and fuel efficiency. Is this true, what are all your thoughts on this. Anyone have one, anyone like it. Is it worth the 100 bucks. Thanks to those willing to respond.
  2. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I use an AIRRAID spacer on my 95 k2500. It gave a very noticable diff. in tourque and a little hp. I did'nt notice but a mile or two diff in mpg. I got mine from 4 Wheel parts Parts for like $75 . It was worth it to me.
  3. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    yeop
    I put one on my blazer and it's a noticable diffrence. Nothing that will throw you back into your seat, but it's noticeable. :DIf and when you install it do not forget to adjust the tv cable after bolting the spacer down. (it's a step i forgot:o)
  4. otisringle
    Aug 2, 2005
    148
    california
    is the tv cable somethnig easy to adjust? Im not to engine smart because I havent messed with them enough to know everythnig about em.
  5. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    TV cables are extremely easy to adjust. Do you have a Chilton's manual for your truck?
  6. otisringle
    Aug 2, 2005
    148
    california
    no I dont, I should probably pick one up though. Im guessing all the info is in there huh!
  7. Blue90
    Aug 27, 2004
    583
    http://coloradok5.com/forums/showthread.php?t=183852 Here's the tread from my installation. Only listen to the people trying to discribe to you how to adjust it. Not the people telling you to make brackets and all that junk. Also here are a few snap shots of the area you should be looking at. (hint)The bottom cable on the right is the tv cable.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    tv cables are not "adjusted" but set..
    Decent spacers come with 2 small spacers to put under the throttle bracket to correct the cable geometry.. If these are not used, sometimes the tv will not have enough length to be properly set..
    To set the tv. depress the "D" release button, pull cable sheath all the way to the firewall, release D button.. manually move throttle to WOT..
    I run a TBI spacer.. minimal gains.. They tend to show improvements at higher rpm's, which TBI's are not known for..
  9. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    I can not say either way as my 1987 305 tbi has a flow master spacer on it when I got it. I can say doing 65mph on FLAT highway she gets 15mpg. Other info on truck is below in siggy. Hope that might help you.
  10. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    Yes, the section to adjust the cable is less than a 1/4 page long. I was going to tell you how to do it (there's only 4 steps) but seeing a picture or a drawing of where the cable is attached helps if you've never adjusted one before. I didn't have a picture but I see blue90 posted one and Ryoken pretty much covered the instructions on how to do it. Good luck.
  11. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    OK I have a wood Spacer between my TBI and the intake manifold and my truck runs fine with no problems and it also shifts fine except some times if i stay on the gas a little hard it will shift a little hard into second but other then that it runs fine. I bought it with it like that from the PO is this a weird thing or not? And would it be a good idea to take my truck to the dealer to see if my TV cable need setting?
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    wood?
    Are you sure it's not a phenolic spacer?
    If you want someone to check your TV setting for you, take it to a tranny shop... They more than likely will just reset it..
    To really check it, you need to read line pressures...
    Just do it yourself...Read my post on it, it's super simple... Go read up over at http://www.tvmadeez.com/article/index.php
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ryoken thats probly what it is. I wouldnt know what to say if it really was wood.
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Haha, don't laugh, I've witnessed lift blocks made of wood... :eek1: :haha:
    Can you imagine someone sitting there whittling one on the porch? :haha: Actually it could be done rather easily with the right saws, drill press and router...
    Read thru that link.. it gets a little confusing repetetive, but it covers everything... PM me if ya got any questions...
  15. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I just PMed you about something else.
  16. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    yup, replied...
  17. otisringle
    Aug 2, 2005
    148
    california
    Thanks for the info guys. Like always, your a bunch of help!
  18. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You will see better power gains with an open plentum spacer over the 2 hole kind. The 2 hole spacers just add more runner length and move the torque curvve down a little in RPM range. The better throttle response gives the feeling of more power. They really dont add power just move it lower in the RPM range
    Open plentium spacers allow your intake to use both barrels of the TB. Increasing air flow = more power.
    See TBI power Plate clicky:cfm-tech.com
    Their Power Charger and injector spacer are also good power adders that give more power and a little better MPG. Their stuff works, and are easy and cheap bolt ons. I have been using their parts for years.
  19. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    You could say your truck has a woody!:haha::p: :haha:
  20. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    x2 :haha: :bow:
