Throttle cable bracket on elebrock intake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zooman, May 1, 2003.
  1. Zooman
    Zooman Registered Member
    Jul 10, 2000
    35
    Ontario Canada
    Ok I finally put my eldebrock carb on my eldebrock intake and I can't remember how my throttle cable bracket goes on. I am thinking that it has to be modified some to fit on the intake.
    What have everyone done for this??
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Check out Jeg's , They carry an assortment of throttle cable brackets in their carb section. /forums/images/graemlins/thumb.gif
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    if you have a pep girls around you they have a bracket that connects to the carb. hope this helps
  4. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    If you go to edelbrock.com and go to tech support, you can look up your model of carb with instructions. Basically, you plug in your make/model/year of vehicle, and it will ask you what products you want, You choose carbs and then what carb you want and it takes you to a description of that carb. On that page, there is a link to the instructions for installation. It's in .pdf format so you have to have Adobe. I'm not sure which Edelbrock you have but here is a direct link for my 600 Edelbrock Performer: http://edelbrock.r-catalog.com/ImgVD/EDE/1403-1413PerformerSeriesCarb.pdf They should have intake instructions somewhere there too.
  5. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Has someone got a picture of there setup?? /forums/images/graemlins/confused.gif
    I found a bracket but do I also need a different bracket for the return spring?
  6. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I had to cut the bracket to fit correctly. I cut off the leg that goes to the pass side of the carb to bolt it down. So, right now, only 1 bolt is used to botl down the bracket but i havn't had any problems with it. I did to my friends as well and no problems there either.
    Blake
  7. Lane
    Lane Registered Member
    Mar 19, 2003
    13
    Montevideo,MN USA
    I have a 79 GMC 1/2 and I used the stock bracket on my Edlebrock intake and Carb
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I run an edelbrock dual plane performer intake and an edelbrock performer 750 on my sb. I just ordered a generic bracket from summit and it bolted right on. It's held on the carb studs so is pretty universal, even has the tranny linkage bracket. Unfortunatly the return spring is a problen and I just got a generic one that is held on by the valvecover bolt but I saw summit also has a return spring bracket that may work as it uses the carb stud bolt.
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I modified the stock bracket but was not happy with the way it was working. I bought a cheapie Spectre universal bracket at Kragan's and it works great. </font>
  10. Zooman
    Jul 10, 2000
    35
    Ontario Canada
    Thanks for the info guys. /forums/images/graemlins/thumb.gif
    Hey Shaggy does that universal bracket you have have a hock up for the return spring?
    I have a th400 so I am not worried about the transmission hock up.
    But I do need to figure out what port on my carb the vaccum line from my tranny goes.
