Throttle Cable Lengthen
Discussion in 'The Garage' started by k20, Jan 10, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Hey, I have a tb spacer on my truck (used to have a 350, now a 496, has a TH400) anyway, the cable is like 1/4inch too short, is there some adjustment on it somewhere? I looked down at the pedal and the little nut on the came is all the way at the end, is there somewhere else im missing seeing it? Thanks.
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    If you have no adjustment there are a few companies that make aftermarket cables, Locar and Spectre are ones I can think of. Maybe a cable from a rig that had a factory big block is longer???????
  3. dyeager535
    26,982
    191
    Throttle cable has no adjustment. Haven't seen any RWD GM that has an adjustable cable, just longer or shorter for the particular application.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    alright guys, guess ill have to either rob the cable from my burban parts truck, or may a 1/4" long bracket.
