throttle cable question
Discussion in 'The Garage' started by dirtwarrior17, Feb 21, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    BBBBBBBBBBAAAAADDDDDDDDD throttle stick
    If i had it in drive i would have gone through the garage. Right now the cable is too long and curled up like a pig tail so it sticks. I want to cut it about 10 inches to fit the holley tbi and manifold. My question is how does the cable connect to the pedal and how easy is it to cut and re-attach?
    thanks in advance
    shane
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    mine is curled around and doesn't stick, you may wanna try lubing yours up or getting a new one.
    IIRC the ends are molded into place so it'll be hard to shorten it.
  3. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Get a throttle cable from a camaro or firebird (f-body) mid 80's carbed version. Mine fit right on my Holley. They are shorter and should cure your problem.
    T.J.
  4. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    cool... im gonna try to lube it first. what should i use wd40?
  5. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    For a quick fix, couldn't you just cut it and use a small cable clamp to hold it on?
  6. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    a cable clamp would work except it would yank out if your throttle spring pressure is too high. on a lighter note you shouldtry some graphite lube to see if you can lube that cable up some b/c my cable is looped and doesnt stick. so try that but i wouldnt try and shorten it b/c that wont last long. get a shorter one from a 83-88 G-body IE: monte carlo, cutlass, regal ETC...
    luke
  7. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I hit it with some wd and it freed it up real nice except for the last 1/8 of an inch on the pedal range. Unless i take my foot off real quick it stays open and sits at about 1000
  8. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    its probably the hollow bell hanging up on sheath out at the TB.. when mine was coming thru the bracket at a little funky angle it would do that.. the loop was causing the bad angle.. wire tied it over to correct but eventually i'll get a shorter cable in there...
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I'll see what i can do....
    thanks for the help.
