throttle cables...Different lengths?
Discussion in 'The Garage' started by broncoman6524, May 30, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    I dunno if anyone can answer this but my truck came with a 305 it now has a 350 and i dont have much foot throttle. When i put my new carb on i noticed that i have a realy long cable (i looped it around electrical wires so it would work)
    Is there a difference in cable lenghts?
    I've gotta order a buncha parts from napa to fix my rearend, and i figured since im buying stuff i should find out and try.
    thnx
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I t should be just long enough to go from the pedal , over the rear of the motor , through the bracket that retains it , and then next to the original Quadrajet/TBI unit . All the trucks I have disassembled or pirated one from worked with each other within the same era , I'e 70's to 70's and 80's to 80's .
    Make usre the little plastic sheath on the end isn't broken and binding . And make sure to use double return springs , and never use it with no springs as it won't return properly without it .
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    all of it is not broken or anything heres a pic. as you can see its too long and i had to loop it. Could it be that the metal retaining clip on the pedal end slid backwards over time?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No , it goes under and into the throttle bracket . And you may have to change the throttle bracket if it don't like your non original carb .
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    its not the original carb, or intake... so what exaclty am i looking for when you say a different throttle bracket?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    One that either fits the intake , if equipped with mounting bosses . Or one that fits on the rear left carb mounting bolts .
    You can get an adjustable bracket from any speed shop or order online . Allowing you to get the cable just right . The pedal should hit WOT by the end of its travel .
    I ran a Edelbrock about 2 weeks on my 83 with the factory manifold and squarebore adapter . That cable was perfect as my 83 uses a bracket on the intake and a cable with short sheath and long wire ,
    On my 77 I would have to buy a throttle bracket as I have a long sheath cable meant for the 70's trucks which have a bracket on the carb back .
    So you may want to get an adjustable bracket from Summit or Jegs and play with the right length .
