Throttle Position Sensor
Discussion in '1982-Present GM Diesel' started by cegusman, Apr 11, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is it used for? Does it need to be hooked up when running a sm465?
  2. DieselBurb
    DieselBurb 1/2 ton status
    Oct 8, 2002
    201
    Mt. Vernon, Missouri
    If you are talking about the sensor bolted to the passenger side of the injector pump, on the TH400, it is used to tell the tranny when to shift and on the 700R4 it is used to tell the converter when to lock-up. If that is what you are asking about, then no, you don't need it for the manual trans.
    Diesel /forums/images/graemlins/burb.gif
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That is what I am talking about. I am tring to remove as much of the wire harness that is not needed, what else can I remove without worrying?
  4. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Chris,
    Please if you don't need the TPS, I would like to have it. PM me with a price if you would like to sell it.
    Mark
  5. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    beat me to it. damn.
  6. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Me Too!!!!!!!
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sent you a PM
