Throttle Return Control help needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bedford boy, Aug 4, 2004.
  1. bedford boy
    bedford boy Registered Member
    Feb 15, 2004
    9
    Sandy,Utah
    I need to reinstall the Throttle Return Control on my 85 Suburban. I think the original was vacuum operated and i can't remember where the vacuum source was. Can anyone please help? I have an electrically operated one from another truck but don't know if i can use it.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Isn't it just a spring that pulls the throttle linkage back closed? /forums/images/graemlins/dunno.gif
  3. bedford boy
    Feb 15, 2004
    9
    Sandy,Utah
    No, It's that solenoid type device that's a part of the emissions system. It's vacuum operated, if you have a Haynes manual chevy trucks 67 to 87 it's on page 6-21. These manuals tend to be extremely vague and it doesn't mention the hook up. The description is "This system opens the throttle lever slightly when coasting to reduce the emission of hydrocarbon". (I think the electrical one i have is a idle stop solenoid..)
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    got the book, never seen one of those, must be a california thing /forums/images/graemlins/dunno.gif
  5. bedford boy
    Feb 15, 2004
    9
    Sandy,Utah
    I'm sure it is, the California emissions.... sorry, smog, is a pain. My truck slightly "backfires" or "burbles" as my daughter says, when i take my foot off the gas peddle. If i keep a little gas and slowly reduce it the noises never occur so i'm thinking this device will cure my problems as it seems to gradually reduce the throttle position at the lower end. This isn't a big deal and not really worth posting but i'm interested if anyone else has these problems. Thanks.
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    ah the luck years of 85 and 86..your screwd..
    ...moves on to next post /forums/images/graemlins/rotfl.gif
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Not familiar with that particular year, but I had a guy ask me the same thing once and after looking at his vehicle I found what he thought was the "vacuum operated throttle return" was actually part of his cruise control system (black canister with rod going to throttle linkage). Not saying this is the case but vacuum operated throttle returns sounds a little scary to me (cracked vacuum lines, disconnected vacuum lines, etc could make for a pretty crappy day).
  8. bedford boy
    Feb 15, 2004
    9
    Sandy,Utah
    The carb has the usual return spring and i assumed that this device "dampened" the throttle slightly when the gas peddle is released. However, i now think that this device actually increases the idle speed slightly when the a/c is turned on, doh.
  9. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I repeat..your screwed /forums/images/graemlins/rotfl.gif
  10. bedford boy
    Feb 15, 2004
    9
    Sandy,Utah
    I thought being screwed was a good thing!!!
