Throttle sping placement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUD_SPEC, Jul 3, 2001.
  1. MUD_SPEC
    MUD_SPEC Registered Member
    Apr 10, 2001
    49
    Does anyone have an E-brock Performer carb with a 700r4 tranny? I'm looking for a place to mount the throttle return spring. The only hole left on the linkage is the big one on top that must be pulled forward to close the carb. Right now I have springs going to a tab(is this what it's for?) on the water neck. Anyone have any ideas? Thanks!
  2. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I ran mine from the big hole on the top to a bracket bolted to the front two bolts on the intake. You can get these relatively cheap at any parts store, but if the setup you have now works, i would stay with it.
    eric
    Don't get me started, you know how i get.
  3. MUD_SPEC
    Apr 10, 2001
    49
    Well, I've rounded up four different springs and they are either too strong or too loose so I was wondering what other places will work. I will prob have to make a bracket like you did.....sounds good. Any pics? Thanks.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine's hooked to a lifting ring on the front of the intake. The ring came on the original motor and I swapped it onto the new one with the Edelbrock intake.
    Tim
