Throttle Spring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Sep 4, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Do TBI engines have throttle springs? I test drove one and I literally had to stand on it to move the accelerator pedal. Just want to make sure something else isnt wrong.
    AW
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I got a TBI, and it has a hard pedel. I am so use to it, I dont care. When people drive my truck they cant even take off.
  3. dyeager535
    26,979
    Carbed vs your guys' TBI I know, but my truck has a nice easy to floor gas pedal, whereas my dads is hard to depress.
    Both are Q-jets, both are cable throttle, so something is obviously binding. Not a very complex setup, I'd check the pedal for binding, (maybe hair or insulation where it pivots?) the cable, and finally the throttle body.
    I believe the pedal comes out really easily, (its disconnected from the cable easily at least) I know the cable can be disconnected and checked really easy, and so can the TB at the same time.
    I HATE hard to depress gas pedals, and when dealing with a manual trans, its even worse.
  4. Yuba K5
    Yuba K5 Registered Member
    Jul 31, 2002
    31
    marysville ca
    yep mines the same way.my right leg was starting to get noticably bigger so i swapped in an sm465 with a manual clutch /forums/images/icons/cool.gif
