throttle sticking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Jul 29, 2001.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    My throttle keeps sticking when I stop at a light or sign. Last time it did this I sprayed some carburator cleaner in it and it fixed it. This time it didn't work and it smells funny when I start it. Any ideas on how to fix it or what's causing it?
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <font color=white>http://community.webshots.com/user/jonathandwill</font color=white>
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Q-jet?
    - Throttle shaft has worn the base houseing. To check, wiggle the throttle shaft, if it has any-play init other than rotational- it's bad and needs to be rebushed w/bronze bushings.
    Twiztid
  3. Jonathan
    Apr 14, 2001
    293
    I'll check that tomorrow, but it should be ok since my carb is supposedly newly rebuilt.
  4. Storm Trooper
    Nov 24, 2000
    4,640
    My throttle was sticking on mine once but it was the calbe to the gas pedel. If you disconnect the cable and try it you will know if it's the carb or the cable. Pretty cheap and easy fix.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  5. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    That happened on my transam try spraying WD40 in and around it that lubed mine and cured it for months until i could afford a new carb
    Theres nothing like fiddling with my Jimmy! 1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31 x10.50 x 15
  6. Jonathan
    Apr 14, 2001
    293
    The cable, right?
  7. dyeager535
    26,975
    Pull the cable off the carb linkage, and see if it binds. Its likely either in your cable or the gas pedal assembly, like carpet wedged in there or something : )
    Is the gas pedal sticking or is your idle picking up because of a maladjusted choke?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  8. Jonathan
    Apr 14, 2001
    293
    something is sticking because if I tap the petal when it does this, it will usually return to normal.
  9. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    A little off the topic, but one time my throttle cable was looped around the cruise control thingofajigger deal. Everytime the truck was flexing it would cause the cable to be pulled tight to full throttle. Not a fun experience when you are close to rolling of a ledge. I simply stripped all the cruise of the truck, did'nt ever work right anyway's. What I am trying to say here is, check to see that your cable is not too short or in a bind.
    Keep it simple!
  10. Jonathan
    Apr 14, 2001
    293
    My thottle shaft wiggles a little bit, but not much and the cable wasn't binding. I think it was carpet jamming up the petal so I moved it out of the way and I'll see how that works. Thanks for the help.
