throttle sticking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DaneW, Dec 3, 2002.
  1. DaneW
    DaneW Registered Member
    Oct 1, 2002
    14
    Washington State
    I was driving home the other day and I noticed that I didn't have to keep my foot on the gas to maintain speed. When let go of the gas the rpms don't come down unless I hit the pedal real quick. I checked all the throttle linkage and didn't find a porblem. It only sticks a few hundred rms above idle, then when I tap the throttle it comes back down. Could this be a carb problem? /forums/images/graemlins/confused.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Disconnect the cable at the carb and see if the lever is binding. Check the pedal at the same time. Then lube everything up real good. It could be the carb, the pedal, or the cable itself. </font color>
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    FIX IT IMMEDIATELY !!!!!!!!!!!!!!!!!!!!!!!!!!1
    This is VERY Dangerous....
    You will not stop if you are on the freeway and go to get off the off ramp.... if it's at Wide Open Throttle!!!
    A new cable is 25 bucks!!!! /forums/images/graemlins/wink.gif
    Go get one now!!!! /forums/images/graemlins/shocked.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have had this with a lot of my GM's most of the times it was the butterfly valves, I just run it and spray some WD40 inside the throttle bore and on the linkage outside.
    I do that every couple of months and when I don't for more than 4 months I get the sticking again.
    Try it.
    /forums/images/graemlins/thumb.gif
  5. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    also, check your return springs, they could be stretched out??
  6. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    also check that it isn't binding on the bottem side of you're air cleaner.
    had this happen before, but mostly after wide open throttle.
    but worth checking.
    dave
  7. blazerman78
    blazerman78 Registered Member
    Oct 16, 2002
    77
    Connecticut
    The same thing happened to me yesterday, but it was a stupid mistake on my part. I just finished my motor a few days ago, and it isn't perfect. I have a Holley 4 barrel off a f*rd that is a pos, but hey, it was free. It idles too fast, and I tried to kick it down before shifting into drive, but, to my surprise, it kicked up! /forums/images/graemlins/eek.gif I almost panicked, and tried it again, but it still didn't work. A 350 at about 4-5000 rpm is pretty scary with my turbo mufflers and dual exhaust, especially when you're not expecting it. This scared the crap out of me, so I shut it off and took a look under the hood, and one of the spark plug wires was holding the linkage open! /forums/images/graemlins/blush.gif I immidiately fixed the problem. I'm glad it happened now, in my yard, instead of on the road!
    Now I just gotta either fix the choke on that damn carb or replace it with one of the ones I have lying around.
  8. DaneW
    Oct 1, 2002
    14
    Washington State
    thanks for all the info guys. I parked it till I can find the problem, don't want any surprises. I'll give those suggestions a try later today. /forums/images/graemlins/truck.gif
  9. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    Bump*
    hehe I am just bumping up this tthread till I fix same problem on my truck. I was thinking maybe timing was getting off? I am going outside right now to try the ideas on this thread that I read.
    Odd thing is, in the morning I do not have this problem,but when it is hot outside, this always happends after a quick push on the pedal. On the way home from work,I hit the gsa hard,idle went UP, I tapped the gas real quick (this usaully works) but no this time. My truck sat in front of my house after I turned it off, and gurgling and then it farted bad. oh well ,outside I go. brb. /forums/images/graemlins/k5.gif /forums/images/graemlins/1zhelp.gif
  10. Dandwg
    Feb 9, 2003
    190
    Turlock, California
    Wala! It seems to be the Throttle spring is stretched out. After I turned the truck on and hit the gas,the idle went UP and I pushed down the lever that the spring was supposed to return and my idle came back to normal.
    Looks like I am making a trip to Auto Zone lol. If it doesn't work,I will post again /forums/images/graemlins/mad.gif
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The return spring helps but most of the times the hi idle system doesn't disengage correctly until you blip the throttle.
    We never got it fixed but learned to live with it.
