Throw out bearing different?
Discussion in 'The Garage' started by justhorsinaround, Aug 7, 2005.
  1. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Long story short, put the 465 in and the clutch pedal doesn't want to depress. There is a 3 finger pressure plate in it now. Does it have to have a different style bearing than the stock pressure plate?
    I'm fixin to head out to the driveway and pull the tranny to find out what the deal is and didn't want to put it back together with potentially incorrect parts.
    Also any thing else I might should look for?
    Thanks in advance.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you have to watch out on this cuz there are two different bearings on these, ones taller than the other
    just have the store look up the bearing and pull it off the shelf- for the pressure plate assembly you go, why didnt you get the disc and plate and bearing as a setup fropm them ?
    good luck
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Allan just called me and he got it all figured out ........ now I get his auto setup :D:D:D:D
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool
    what was the deal with the bearing ?
  5. justhorsinaround
    Sep 16, 2003
    6,798
    Well that was a lesson learned. Turns out that when we put the tranny in the first time the clutch/throw out bearing fork hit the exhaust and jammed it onto the bearing causing it to bind. :rolleyes:
    Easy fix but annoying in that the tranny had to be dropped to find out the issue. Fortunately, the tranny just kinda fell back in so that was nice.
    Anywho's a word to the wise.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nice! good thing you caught that one, good thing it was solved without too much trouble(relatively)
    good luck
    :D
