throwing a rod?
Discussion in 'The Garage' started by tecton, Apr 1, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    whats it look like?
    what exactly happens?
    any pictures?
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Usually the wrist pin breaks or a rod bolt breaks or the rod ust breaks in half and the rod literally gets thrown through the side of the block or through the oil pan...Usually if it is a nice throw, you will see a huge hole in the side of the block and the rod will be sticking out.
    Chris
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I should have taken pictures of mine.
    Rod bolts stretched, rod bearing spun, rod broke, and went through the block and the oil pan.
  4. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    My BMW currently has a bad rod. It's been going downhill for years, but it finally threw it a couple months ago. It makes a horrible knocking sound when it runs, probably the rod hitting the side of the block. Amazingly it still runs, though. /forums/images/graemlins/eek.gif
    Say all you want about BMW's being yuppie cars, they're some of the best built vehicles ever. Come stock with a forged crank (probably the only thing keeping mine alive).
    I've also seen my dad's built 327 chevy go. From what we can tell, it revved to high and a piston caught the bottom edge of a cylinder wall. Piston grenaded (biggest piece we found was about the size of a quarter) and the rod spun around taking out everything. The oil pan was hacked in half and the block had a huge chunk missing from it. It was pretty cool looking. You could see daylight straight through the middle of the block /forums/images/graemlins/blush.gif
