thumping in under my console.
Discussion in 'The Garage' started by LAXandBLAZERS, Nov 26, 2002.
  1. LAXandBLAZERS
    LAXandBLAZERS 1/2 ton status
    Jun 2, 2002
    100
    Durham North Carolina
    when i take off from a light of just a stop sign fells like my drive shaft is comming through the floor board. does any body now what and how to fix this started after 4-wheeling thanks. /forums/images/graemlins/k5.gif
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    [/ QUOTE ] </font><blockquote><font class="small">In reply to:</font><hr />
    [/ QUOTE ] did a squirrel crawl into you're console?
  3. LAXandBLAZERS
    Jun 2, 2002
    100
    no i thought that my transfercase was lose.
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    go under your vehicle with it in park and turned OFF...
    Start pulling and shaking things...
    See what moves the most :d
  5. muddysub
    Jun 23, 2001
    10,452
    489
    and let the squirrel out. /forums/images/graemlins/laugh.gif
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Researchers from the University of Ash have found that the "thumping" is axlewrap binding the universal or the tranny/t-case mount is shot and needs replacing. Just a few things to check out.
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Check your t-case mounts. If I have my truck in first gear and punch it real hard the engine torques up and slams the t-case against the floor. I replaced one mount (couldnt afford the other) and it cured part of the problem.
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    check your u-joints.
  9. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Check your u-joints and tranny mount...
  10. LAXandBLAZERS
    Jun 2, 2002
    100
    Thanks all will start checking this weekend after I get all the MUD washed out from the journey to the backyard. HAHA. (got stuck for the first time /forums/images/graemlins/blush.gif). Anyway thanks /forums/images/graemlins/k5.gif
  11. reddog64
    Nov 9, 2000
    3,325
    OK.. where's the pictures? /forums/images/graemlins/eek.gif
  12. muddysub
    Jun 23, 2001
    10,452
    489
    Thanks all will start checking this weekend after I get all the MUD washed out from the journey to the backyard. HAHA. (got stuck for the first time ). Anyway thanks
    [/ QUOTE ] AHH, my first stuck was in my back yard too. had my (then) stock suburban up to the bumpers in mud in my back yard. /forums/images/graemlins/grin.gif
  13. hardcore71
    hardcore71 Registered Member
    Nov 21, 2002
    86
    Weare NH
    Had this same exact problem. The t-case is hitting the floor. This is caused by eiher a bad t-case/tranny mount or more likely bad motor mounts (especially the drviers side). The engine lifts under torque and takes the t-case with it until it hits the floor. A cheap fix is to chain the drivers side cylinder head to the frame to keep it from moving or you can just replace the mounts.
  14. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine did this whe ni first bought it...i guess when the tranny got rebuilt the shop forgot to put the bolts back on for the mount, so the transfer case just sat on the mount and did that under acceleration...
  15. CK5
    May 19, 1999
    21,627
    704
    CO
    Same thing happened to me a long time ago, it was the drivers side motor mount.
