thunk in the rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bosardk5, Apr 30, 2002.
  1. bosardk5
    bosardk5 Newbie
    Apr 30, 2002
    4
    86 k5 blazer, the rear or transfer case has a thunk at take-off and between first and second. Not a bad noise but it is noticeable. what should I look for?
  2. Batchman
    Batchman Registered Member
    Apr 9, 2002
    54
    Oklahoma
    Could be transmission mount or motor mounts?
  3. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    The last time I heard that, my rear diff was cracked in half. You may want to open up the cover and check it out.
  4. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    Could be a bunch of things...
    * Bad U-joint
    * "Chevy clunk" - something some axles do... I think ring and pinion slap is what causes it
    * Excessive ring and pinion backlash (related to above)
    I'd pull the diff cover and inspect the running gear. It sux having something driveline related come apart when you're going down the road.
  5. bosardk5
    bosardk5 Newbie
    Apr 30, 2002
    4
    Thanks, I found that the bolts that hold the transfer case in had come loose.
