Thunk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JeremyK5, Aug 23, 2001.
  1. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    When I go from neutral to reverse, I get a fairly loud thunk. When I go from neutral to drive, I get almost no thunk. Does anyone have an idea what would cause this? I have a th350 transmission in a 75 Blazer.
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    That's a typical symptom of a U-Joint gone bad. Check your rear driveshaft joints for wear.
    If they're fine, you should check out your tranni and transfercase mounts to make sure all the bolts are tight.
    Thomas.
    -- '84 K5 Blazer --
