tick tick tick ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bowtied, Feb 18, 2002.
  1. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    Howdy all, My 87 350 tbi has picked up a "ticking" noise. It is most pronounced when accelerating and engine temp has little or no effect. I'm thinking maybe a lifter? Is there any quick fix if it is a lifter or will I have to replace them?
    Thanks, Bowtied
  2. BrianK5
    BrianK5 Registered Member
    Sep 20, 2001
    58
    Omaha, Nebraska
    I've been dealing with a tick also. It only ticks when accelerating and gets faster with speed. I've narrowed it down to the EGR solenoid. Where is the tick coming from? Make sure it's not something on top of the engine before you tear it apart to get at the lifters.
    1985 K5 Blazer
  3. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Check timing then if you have to adjust the valves before you start pulling lifters and also make sure your oil dip stick reads full.
    Eat More Mud!!!
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My dad has a Ford F150 that has a tick. It has been diagnosed as a lifter, and he just lets it run. It has been running for 20K with the tick and we haven't had any problems related to the lifter sofar. The rest of the truck is a POS, but the motor still runs fine. The ticking is the reason my dad even got the truck. It was a work truck at hs work, and his boss was convinced it was a rod tapping, so he sold the truck to my dad for $1. It has 20K on it or more since we got it with the ticking the whole time. No problems yet.
    My Chevy isn't broken, its just out of gas.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Make sure that you've ruled out a exhaust manifold leak before you start worrying about internal engine problems. I had a 74 Chev 1/2 ton with a similar ticking - I was positive it was mechanical because it sounded too much like a bad lifter. It ended up being a loose exhaust manifold.......
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I second Canmore on that. Exhaust manifolds no matter how convinced you are can be so decieving I once thought I had a tick as well from a lifter and it was the manifold....dont be fooled if you haven't checked the maifolds lately check them first.
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    Check to make sure that it is not pinging by filling up once with premium or by retarding the ignition a few degrees. Then you could try some of that "honey" that they sell to help quiet valvetrain noise. It would not be a good permanent fix, but if thickening up the oil makes it go away, that helps you narrow down the problem.
    <font color=green>Top signs you don't have a real 4x4:
    4) Twin Traction Beam
    3) Made by D.C.
    2) 5 lug nuts
    1) Unibody</font color=green>
  8. Bowtied
    May 21, 2001
    69
    NC
    Hey guys thanks for the good info. I'll have to see if I can tighten them down any. I hope that's it, I really don't have time for any major repairs right now.
    I do appreciate ya'lls help.
    Bowtied
  9. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    this happened to the sub, it was a valve and we had the heads rebuilt. not saying you need to have a head job done but that's what happened to us.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  10. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I'm going through this right now. Mine comes and goes, sometimes when I start it, sometimes not, usually after a long drive at a constant speed, then it starts when I accelerate after stopping. Yesterday it dd something wierd, it actually stopped ticking before I shut the motor off... I'm swapping it out today, and then rebuilding my motor after I yank it... Much faster solution for me than tearing the motor apart in the truck and losing use of the truck for however long that will take, and I'm not even sure if where it is....
    Ratch
    CK5 album
    Your ad here.
  11. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I have the same problem on my S10 and I notice when fuel sprays in the throttle body that one of the nozzles spray in bursts causing a ticking sound. $.02
    "We all gotta go sometime.... Race ya"
