Ticking like a Timex
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dcryer, Jan 27, 2003.
  1. dcryer
    dcryer Newbie
    Sep 3, 2002
    California
    I have a 84 K-5 5.7L. The problem I am having is when I start the truck up in the morning, it sounds and runs fine (when its cold) but when it warms up I get a ticking noise. It only happens when there is a load on the motor, not when its idleing. I was hoping its an exhaust leak...hopely its nothing serious. Can anyone give me a little insite as to what it might be? Thanks
  2. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    sounds like an exhaust leak. it may also be your rocker arms tapping but i think it would do it all the time if it was rockers. Tice /forums/images/graemlins/k5.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Same as above..also, do you have headers? sometimes they can make a ticking noise that sounds like it could be something else
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds like exhaust to me does it change with the rpm?
  5. dcryer
    dcryer Newbie
    Sep 3, 2002
    California
    I have stock headers. The sounds gets worse with increased acceleration, but when I ease off the gas it kinda goes away. Like I stated before, you don't hear the noise at idle only when I put a load on the engine. Thank for reinforcing my first thought, because I thought it might be an exhaust leak. I will work on it this weekend.
    "Happy Wheeling All" /forums/images/graemlins/thumb.gif
  6. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    start it up some cold azz nite, like cold enough to see exhaust steam, then look under the hood and under the rig for any steam comming out where it isnt supposed to with a flash light.
  7. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Just start it in the dark.If the leak is big enough to hear inside truck you should be able to see it.Run RPMs up bout 2500 or so and let off quickly.Should see light flash at leak. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  8. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    the clicking doesnt mean its a back fire, just means that it is leaking before the muffler, good idea though. also look at all the joints and look for ant soot. mine did this and it turned out to be a broken manifold, but the crack was behind the stupid heat sheild
