Ticking me off
Discussion in 'The Garage' started by TDAWG1, Mar 4, 2007.
  1. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    Warn Premium lockouts on the front. Worked Awesome. Got 1200.00 in break work done from Big O tire, yeah first mistake. But now Driverside hub gets tighter and tighter when going from free to lock. tight enough that I can't get it to the lock side. What gives! opened it up packed full of greese , that sucked, Anywho it turns pretty free when its not attached but when I put it back on tighter. AHHHHHHHHHHHHHHHH!!!!
  2. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    id love to help ya out, but i myself have yet to work up the balls to open up one of those hubs, so im not sure what the problem could be :confused:
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    There really should not be very much grease in the lockout hub. That could be the problem.
    The hub only requires a light coating of grease.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Ditto, I was always under the impression that you were not supposed to pack grease into lock outs, too.
  5. TDAWG1
    Jan 18, 2005
    2,836
    8
    thats whaT I always thought too.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Your thinking is correct. Even the papers that come with the hubs should say not to pack grease in them. Just lightly coat them.
  7. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The instructions on my mile marker hubs say to use no grease at all. Makes sense if it turns easy when hot and hard to turn when cold.
