Ticking noice on passenger side of engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, Jan 4, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Anyone know what that could be? Sounds kinda like an exhaust manifold leak but I'm not sure. Exhaust manifold was changed two years ago.
    /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
    Doesn't sound serious but sounds abnormal.
    TIA /forums/images/graemlins/smile.gif
  2. yotapunk
    yotapunk Registered Member
    Jan 3, 2003
    23
    southern CA
    MY 90 is getting a clicking or grinding noise coming from the vaccum line that plugs into the valve cover. Can you narrow down where the noise is coming from?
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    It could be plenty of things...from exhaust manifold like you said, to out-of-adjustment rocker arms, to a bad lifter or two. Unfortunately, we're going to need a better location of the noise to properly diagnose the problem.
    My engine has had pretty severe lifter/rocker noise for over 100,000 miles. Still going strong...so don't wreck your brain over it.
  4. K5Kell
    K5Kell Guest
    I am having the same ticking problem on my 87. it sounds like it is coming from near the valve covers on the passenger side. im not to worried about it but it does get annoying.
    -Kell-
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I didn't get much of a chance to lesten close. Thanks for setting me at ease. I plan on getting some Vortec Heads next summer. Maybe the noise will go away when I have those done. Still deciding between a TBI swap or carb rebuild...
    /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Chris, remember what the ticking on my truck sounded like in Pismo?? is yours like that??
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Get a long screwdriver, pry bar, board, whatever and place against where you suspect the noise. It will act sort like a stethoscope and make the sound more audible. Near the manifolds will have a slight tick tick tick from the valves working. Do you have a manual tranny? Worn throw out bearings like to tick and make noise.
  8. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Naw... It's quieter than that but I'm not sure if it sounds like it can get louder. I'm not sure if it's just me being paranoid but I think I hear a manifold leak when I get on the gas in gear(on the road).
  9. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I'll try that. I was thinking about getting a stethoscope from a friend of mine thats a nurse. /forums/images/graemlins/thumb.gif
    Its automatic.
  10. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Passenger side? It could leaking from the exhaust flaper. Mine leaks from there until the truck gets hot, then goes away. /forums/images/graemlins/k5.gif
  11. 4x4 Cowboy
    4x4 Cowboy 1/2 ton status
    Dec 7, 2002
    236
    california
    you may have a dry lifter
  12. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i dont know what year model you have but i had a 80 model that made some noise on the right side it turned out to be the frigging fuel pump. i thought it was something major but thats the way i allways think.
  13. 4x4 Cowboy
    Dec 7, 2002
    236
    california
    was the fuel pump bad
  14. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i've had a loose fuel pump bolt do that. is it speed or rpm dependant...or independant of both?
