Ticking* noise*
Discussion in 'The Garage' started by hi pinion, Aug 3, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    When i start my truck up, it does this really fast clicking noise,,, by the firewall somewhere, sounds like something electrical, i dont think its the wires, it clicks like 5 times per second. Its an all the time deal, it sounds similar to a taser sound. Is this normal? Its an 85 full size CCC model.
    Anyone? :laugh:
  2. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    I would say a lifter....but I make pickles and I'm not a mechanic :D .
  3. hi pinion
    Sep 25, 2003
    5,354
    Whell, mabey its the "card in the spokes" i might have to take out . :D :haha:
    Common! Anyone else have a ticking noise?
  4. hi pinion
    Sep 25, 2003
    5,354
    No, it aint a lifter, i can hear its an electrical clicking noise. :confused:
  5. nc87k5
    Sep 23, 2003
    5,231
    North Carolina
  6. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    If it doesn't vary with engine RPM, and you're sure it's electrical, It sounds like it could be a malfunctioning relay, or a circuit breaker with a short.
    -Mike
  7. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Mystery Ticking Sound
    Check for an EXHAUST LEAK. This is a common sympton of an exhaust system leaking near the engine.
  8. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    my injectors tick on my tbi. but 85 wouldnt have that so :confused: , try spraying a mist of water at all your electrical and see if something sparks (do it in the dark of course) i had to do that with my furd, worked pretty good.
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Check the disty cap, I had taken the tranny out and had the motor resting against the cap. It ended up shifting the cap and the rotor was hitting the cap making a ticking sound.
  10. hi pinion
    Sep 25, 2003
    5,354
    that sounds feisable,, i woulod know where to start with that though . :doah: What sort of relay to buy? :doah:
  11. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    assuming it did vary with RPM, what would u have said it was?
  12. hi pinion
    Sep 25, 2003
    5,354
    It dosent vary.
  13. CustomChevy
    Jun 29, 2005
    4,328
    indeed, but a friends truck has a ticking that does
  14. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I would suspect a exhaust leak. Re-tighten your manifold or header bolts.
  15. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    Did you check the spark plug wires? See if any have become burnt or cracked due to exhaust heat. If you dont see any physical sign then start the motor. Spray water on the plug wires and see if it help with finding your tick.
  16. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    That's what I was going to suggest as well... a bad wire could be the problem. One could be burnt through, or worn through and arching onto something... makes a nice little ticking/popping sound.
  17. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    I have that same problem, but I don't hear it in the engine bay, just the "cab".
  18. dyeager535
    26,980
    It's your mix control solenoid pulsing. :)
  19. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    An exhaust leak would vary frequency with engine speed, as would the rotor, injectors, spark plug wires, etc.
    Do all electrical components function right? HV(AC), horn, headlights, blinkers, cab lights, wipers, etc? Is it inside the cab or in the engine bay? Could you use the old rubber hose stethascope trick to pinpoint it's location closer?
    I had a ticking relay whenever I'd honk my horn in my old '79 and it turns out it was my horn control relay way up above the steering column was dirty. Pulled it out, cleaned the contacts and it worked up until the day I sold it.
    In your case, if it is in fact a relay, you should be able to pinpoint it by touching it and feeling it clicking while it's doing it. When you find it, shut 'er down and pull that relay then start it back up and see what happens. If the ticking stops take the dead one into any auto parts store or radio shack and put it on the counter and say give me a new one of these :)
    Good luck
    -Mike
  20. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    while running get it all wet and run ure hands on all the wires- ull find a elect leak that way :eek:
    fuel psi relay or bypass? put some marvel mystery oil in ure gas if u can drive it around
