Ticking
Discussion in 'The Garage' started by bobalob, Jan 7, 2006.
  1. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    This dang ticking noise started about a month ago real quiet and has steadily gotten louder and now I can hear it over the no cats, little flowmasters, dual exhaust(loud). First thing I did was listen to the top end(just put new cam and lifters in about 5-6 months ago) but the origin was lower and farther back. Started looking for some holes in the exhaust but found nothing. Now as I hang from the frame like a monkey(ground is about 3 inches of mud and water:p: ) the noise seems to be eminating from the clutch area between the exhaust pipes. Is this possible? Whats going on? The throwout has been squealing occasionally and sometimes(pretty rarely) the clutch will slip and burn at a ridiculous rate(not lately). I have never even seen whats inside the bellhousing:o so I am kind of hoping the problem is located there giving me a reason/chance to see whats what. First off I was planning to adjust valves and get a better listen to the top end to reassure myself that is not where the problem resides. Any ideas or suggestions would be great as I am most definately a noob:laugh: . Oh it is a 79 K5 3/4ton carbed 350,465,205.
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I know you checked but if you have manifolds check again. I searched a few times on mine and never found the problem until I replaced the gaskets.
  3. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    pop open the cover and check the flywheel bolts. I had one loose and it made a really strange ticking noise.
  4. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    sounds like the throw-out bearing.does it change in sound when you push in the clutch? If it does than deff. throw-out.
  5. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    yeah when driving in gear ticking is loudest and when clutch is depressed the majority of what I can hear over the exhaust is alleviated. Any which way it sounds like now would be a good time to replace a tired clutch, throw out, and have flywheel resurfaced?? Any tips/tricks to dropping/reinstalling tranny/transfer/clutch, or can they just be unbolted and pushed back? Also decent clutch kit for cheap suggestions. Thanks:bow:
  6. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Borrow or rent a tranny jack. This makes this much,much easyer also grab a buddy as the 465/205 is a heavy pig. Definetly re-surface the flywheel. as far as a cheap clutch any factory spec. remanufacture should do fine. A tip on re-install is to make sure you get the clutch linkage adjusted properly, 1/8-1/4 of an inch of free play is about right. Removal and reinstall pretty strait forward, lots of grunting and sweating! dont wait to long as the trow-out can scar the input shaft. good luck and if any ? let me know.
  7. tolovana
    tolovana Registered Member
    Nov 26, 2005
    16
    Eagle River, AK
    If the clutch linkage is in order and adjusted properly, the throwout bearing is out of play and won't make any noise. The only time it can make noise is when the clutch pedal is depressed which engages the throwout bearing whith the clutch pressure plate. No matter it sounds like you need some clutch work anyway. Drop the t-case, drop the tranny, and the rest is pretty easy. The tranny jack will help but isn't necessary if you've got a couple of strong friends to help. As for the ticking noise... If you're running headers, I bet a dollar to doughnuts you've got a small leak. Replace the gaskets top and bottom. Good luck...
  8. bobalob
    Jul 20, 2005
    157
    Everson, Washington
    Yup headers and I am going to replace top gaskets(welded on the bottom) and do another check for holes/leaks before moving on to the clutch(would prefer to put off for another 1-2 months). Also was thinking of cutting out sections of header to block flange at this time.
  9. tolovana
    Nov 26, 2005
    16
    Eagle River, AK
    You might try to just tighten the header bolts. The two on the back always seem to give me fits. If it's still rolling I understand the waiting a couple of months on the clutch... Probably still pretty wet down there. Here I would be lying on a 2" thick sheet of ice. I use a cheap plastic sled to slide around on; not the most fun I've ever had.
