Tie rod and drag links
Discussion in 'The Garage' started by berg76, Apr 13, 2004.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I'll be installing a crossover steering/high steer setup in the coming months and a question popped into my head about draglinks and tierods. I want to run regular TRE/DLE instead of running heims. What ends do you run? I know alot of people upgrade all there joints to 1 ton but why should I switch from my current type?
    Same question with rods. Do tie rods really break that easy under steering pressure? Im going high steer so bashing it on rocks is not a concern. I was considering making my own tie rod and drag link out of the stock 10bolt rods I have (2). 1-1/8" i belive and the threaded ends are there allready there. Just have to change the length.
    Thanks!
    ~Jason
