tie rod and stabilizer
Discussion in 'The Garage' started by mccomas, Nov 25, 2005.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i am replacing my OEM tie rod with 1 ¼ tubing. obviously the tubing does not have a ‘mounting hole’ on the driver’s side to mount up my steering stabilizer. can someone provide me with a part number for a stabilizer that mounts to the stock location on the axel (it is a 87 d60) but uses some type of u strap to mount up to the new tire rod? thanks…
  2. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I know Rancho has a kit that uses 2 u bolts and an L-bracket. I got mine through Carquest for about 25$. It worked pretty good on my custom tie rod bar for the 44f i used to run. dont have a part number, sorry!
  3. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
  4. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    stock dodge solid axles with coils use a clamp on mount. not sure of the size bar tho. goo easy find in the parts yards.
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You do know that you can get a TRE with the hole in it right?
    This would be the easiest way to fit the stabilizer. You would have te cut the DOM shorter though
