Tie Rod End help please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NEK5, Feb 2, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Other than the fact that the grease looks a little old, I can't see anyhting wrong in the pics. What do you see that concerns you?
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    in the first pic....it shouldn be like that right
  4. Can Can
    15,552
    136
    Sorry, I'm not getting ya'. It shouldn't be like what?
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    it is kindof cocked up to the front and its missing the plastic/rubber thing and i can easilly spin the tie rod to put it back the way it should be
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Have someone turn the steering wheel back and forth while you watch the ends for any play. It would be a good idea to get the rubber dust cover thing back on the one end if it's still good, otherwise replace it.
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thanks for the help guys...just got back from auto zone and got the new TRE..only 20 so well worth it in my eyes
  8. Can Can
    15,552
    136
    The tie rod should be able to swivel in the joint........
    And if you plan on replacing parts, please don't opt for the cheapest stuff you can find. If you wanna start swapping in new front end parts, spend the coin and buy yourself some quality Moog parts.
  9. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    quick question
    what is this for and where does it go??
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok thanks for clearing that up. the only reason why i went with the autozone 20 dollar special was because i just wanted a temp fix to see what it would do. it was pretty worn so i figured i would just through one of those in and if i decide to keep it in it has a lifetime warranty. i mean replacing it is not gonna hurt anything..it was missing the rubber thing and it moved alot easier than the one i put in does so i`m hopin it helps a bit
    hey do you think you could give me some info on Moog i might buy some of their stuff when i start doin some wheelin
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    well they are actually not too much differnt
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    4get it i`m returnin it!
    i was mislead on the play...my buddys dad said thats how they get as soon as you drive once with it in so i`m steeling the rubber thing and returnin it!!!!
    i love ripping off stores!!!even thought the rubber things cost them 10 cents oh well!!:haha: :haha:
  13. Can Can
    15,552
    136
    The little thing you've pointed to with the arrow is a grease fitting. There should be a small threaded hole on the bottom of the TRE that the grease fitting screws into.
  14. Can Can
    15,552
    136
    Like I said........:whistle:
    What are you referring too? What's not much different?
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    the play
  16. K5Kell
    K5Kell Guest
    Thats the grease zert, thread it into the back in the little hole, Then when its back on your rig pumb it full of grease with a gun. Good idea to regrease after offroad use to keep dirt/water out of the joint.
    -Kell-
  17. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    For the $20 I would have just swapped it in...in fact I would have got a pair and swapped them both in. It's pretty hard to replicate that 'play' when the TRE isn't attached to anything.
    Rene
  18. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i installed the other one and it was the exact same so i took it back out and kept the rubber thing and put my other one back on
