Tie rod end question
Discussion in 'The Garage' started by ryan22re, Oct 17, 2006.
  1. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Will 1 ton tie rod ends fit where 1/2t tie rod ends go?
    I have a 1ton low steer tie rod I want to install in place of my 1/2t
    Thanks in advance.
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    60 parts dont realy swap to 10/44 axles. i think its no. been coverd before. wider axle.
  3. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Like said, the 10/44 tie rod would be longer. Helped a buddy swap a 60 in place of his 10 and we were able to cut it down enough to work. Luckily the threads were deep enough in 10b tie rod that it worked.
    I guess it would depend on how the 60 tie rod was cut as to whether or not you could get them to work.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Thanks guys, looks like my luck has worn out, the front driveshaft is busted too, have to drop back and punt.
