Tie rod metal qualities?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Apr 26, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    What is a tie rod made out of? Mild steel or an alloy? I am going to make one in a few weeks because mine is all bent to hell.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is mild steel. Just about everything on a chevy is mild steel to keep costs down.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    1.25"x0.219"wall is almost perfect for tapping 7/8"-18tpi
  4. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    How thick, and what wall thickness is a stock tie rod? Woud it be better if it were solid?
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    how thin is a better way to put that
  6. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Ok. how about what O.D. and what wall thickness is a stock rod?
  7. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  8. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    Thanks for the info. I have enough now to start construction.
  9. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I just had mine made out of t-6 aluminum solid. Hopefully it will be stronger than stock (LOL).
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I hate to tell you but unless you went huge in the diameter it will only be 1/3 as strong as stock /forums/images/icons/frown.gif
