Tie Rod question
Discussion in 'The Garage' started by sandawgk5, Nov 6, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I need to know the size of a factory Dana 60 tierod. The diameter that is. I am having a piece of flat bar bent at work for my Hydro mount and I need to know the diameter to calculate the bend radius and where to punch the holes to mount the ram.
    Ira
  2. sandawgk5
    Oct 28, 2003
    6,881
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Stock Dana 60 parts are in bold.
  4. sandawgk5
    Oct 28, 2003
    6,881
    So how big is the tie rod itself where my mount will be welded 5/8"?.
    Ira
  5. sandawgk5
    Oct 28, 2003
    6,881
    Never mind, I see the thread is 7/8-18 so the tierod should be 1" or 1 1/16" I think if I put a radius for 1" diameter on the bend I should be able to massage it from there.
    Ira
  6. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    The stock tie rod (ES2011R) has 1" diameter shaft. That part number is for the small side anyway. The threads are 1" by 18 pitch. The long side is the whole bar with the tie rod at the end which is one piece. The tie rods that are used by most aftermarket companies for the dual end tie rod is 7/8" by 18. What I didn't look into before I purchased the 1.5" ORD tie rod kit is the size of larger tie rod ends ala Freightliner, Kenworth, Peterbilt, etc. I'm happy with my ORD kit even though it has a 7/8" tie rod.
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I just went and measured the factory tie rod from my 1985 D60 and it is 1.130" diameter.
  8. sandawgk5
    Oct 28, 2003
    6,881
    Great thanks guys. I can give the MRs that diameter and they can bend it for me:D. How far should the holes be from the tierod? I am thinking 1.5-2 inches. I guess I need to mock it up and get the ram parallel to the axle housing yes?
    Ira
